hello
how can i write an internal interrupt code which do subrotine when the key of the key pad is pressed , like reset key ;
and how can i make a back key in the keypad ,
thank you _________________ A.T.N
Posted: Fri Jun 08, 2007 12:33 pm
How can I write an internal interrupt code which do subroutine
when the key of the key pad is pressed ?
