I need a little help with getting PWM to start on pin RB3 of the 'F819.
I've read many of the posts and tried many of the recommended solutions. I just can't get the thing to work!
I'm trying to fire up a h bridge using PWM multiplexed on the low sides.
#FUSES HS //High speed Osc (> 4mhz)
#FUSES PUT //Power Up Timer
#FUSES LVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES CCPB3 //CCP1 input/output multiplexed with RB3
#use delay(clock=10000000)
#define PWM_In PIN_A0 //
#define Current PIN_A1 //
#define HiSideA PIN_A2 //
#define HiSideB PIN_A3 //
#define HiSideC PIN_A4 // Not used
//#define ----- PIN_A5 // Not used
//#define ----- PIN_A6 // Not used Xtal
//#define ----- PIN_A7 // Not used Xtal
