Need to start PWM on PIC16F819
motorjunkie
PostPosted: Sat May 26, 2007 2:47 pm     Reply with quote
Hi guys,
I need a little help with getting PWM to start on pin RB3 of the 'F819.
I've read many of the posts and tried many of the recommended solutions. I just can't get the thing to work!
I'm trying to fire up a h bridge using PWM multiplexed on the low sides.
Any ideas how to solve this?
Here's my code>>
#include <16F819.h>
//#device ICD=FALSE
#device adc=8
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES HS                       //High speed Osc (> 4mhz)
#FUSES PUT                      //Power Up Timer
#FUSES MCLR                     //Master Clear pin enabled
#FUSES LVP                      //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES NOCPD                    //No EE protection
#FUSES NOWRT                    //Program memory not write protected
#FUSES NODEBUG                  //No Debug mode for ICD
#FUSES NOPROTECT                //Code not protected from reading
#FUSES CCPB3                    //CCP1 input/output multiplexed with RB3
#use delay(clock=10000000)
#define PWM_In       PIN_A0    //
#define Current       PIN_A1    //
#define HiSideA       PIN_A2    //
#define HiSideB       PIN_A3    //
#define HiSideC       PIN_A4    // Not used
//#define -----       PIN_A5    // Not used
//#define -----       PIN_A6    // Not used Xtal
//#define -----       PIN_A7    // Not used Xtal
#define LoSideB       PIN_B0
#define LoSideA       PIN_B1
#define LoSideC       PIN_B2
#define Mtr_PWM     PIN_B3
#define Tacho_out   PIN_B4
#define HallC       PIN_B5
#define HallA       PIN_B6
#define HallB       PIN_B7
void InitMCU()
   setup_adc_ports(AN0);
   setup_adc(ADC_CLOCK_DIV_2);
   setup_spi(FALSE);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_256);
   setup_timer_1(T1_DISABLED);
   setup_timer_2(T2_DIV_BY_1,500,1);
   setup_ccp1(CCP_PWM);
   setup_oscillator(False);
    InitMCU();
    InitHW();
        set_pwm1_duty(200L);
        output_high(Tacho_out);
        output_low(Tacho_out);
    do
    output_high(HiSideA);
    output_high(LoSideB);
    output_low(HiSideA);
    output_low(LoSideB);
    }while(TRUE);
PostPosted: Sat May 26, 2007 2:54 pm     Reply with quote
What pin does LVP use?.
Do you think this will work with a CCP output multiplexed onto it...
PostPosted: Sat May 26, 2007 3:16 pm     Reply with quote
Doh!
I've changed the LVP to NOLVP and now it works!
Many thanks Grand Master Ttelmah, many thanks!
