AdamkT1
Data storage by SPI on 18F452s |
Posted: Mon May 21, 2007 8:25 pm |
Friends,
I am trying to save data in the EPROM memory of 18f452. The code is very simple which I copied from CCS examples.
One 18F452 is acting as a master and the other 18F452 is emulating 9356 EPROM.
I am trying to write to an address and then read from the same address.
Later, I would put the data on a port for display/debug purpose.
The problem, I am having in Proteus is the following message.
[PIC18] PC=0X0000 $MCLR$ is Low. Processor is in Reset U2(SLAVE)
[PIC18] PC=0X0000 $MCLR$ is Low. Processor is in Reset U2(MASTER)
Does it mean that I have to power the MCLR pin.
Both the codes, the master/slave is pasted below.
'===============U2(SLAVE)====================
#include <18F452.h>
#use rs232(baud=9600, xmit=PIN_C1, rcv=PIN_C0)
int8 memory[80], data, instr, address;
void write_data(void)
PURPOSE: Reads data from SPI and writes it to memory
PARAMS: none
RETURNS: None
while(!spi_data_is_in());
data = spi_read();
if(address >= 0 || address <= 80)
memory[address] = data;
BYTE read_data(void)
PURPOSE: To read the memory
PARAMS: none
RETURNS: Data stored in memory
return (memory[address]);
PURPOSE: Peripheral Initialization
setup_spi(spi_slave | spi_h_to_l | spi_ss_disabled);
while(true)
instr = spi_read();
address = spi_read();
if (instr == 0x18)
instr = spi_read(memory[address]);
else if(instr == 0xa)
write_data();
'==============U1(Master)==========================
#include <18F452.h>
#use rs232(baud=9600, xmit=PIN_A0, rcv=PIN_A1)
#include <9356spi.c>
BYTE PORT_A;
int8 value;
EEPROM_ADDRESS address;
address=1;
init_ext_eeprom();
do
WRITE_EXT_EEPROM( address, 35 );
value=READ_EXT_EEPROM( address );
PORT_A=value;
PORT_A=0;
} while (TRUE);
'======================Code End==================
Thanks. |
Posted: Tue May 22, 2007 1:01 am |
When posting code please use the 'code' buttons to preserve formatting.
Quote: | The problem, I am having in Proteus is the following message.
Does it mean that I have to power the MCLR pin. | Use the search function of this forum and type 'proteus MCLR', select the 'search for all terms'option. This will give you 5 hits. Read http://www.ccsinfo.com/forum/viewtopic.php?t=28419&highlight=proteus+mclr
Short: Yes, you have to connect MCLR to the positive power supply.
Your check for memory buffer overflow is incorrect.
Code: | if(address >= 0 || address <= 80) | Change this to Code: | if(address >= 0 || address < 80) |
AdamkT1
SPI between two 18F452 |
Posted: Wed May 23, 2007 9:16 am |
Hi friends,
Still having troubles with SPI between two 18F452s. The slave is emulating 9356 EEPROM.
Below is the modified code. I hope somebody would help me solve this problem.
The error(s):
1) In Proteus, the error is : [PIC18 MSSP] PC=0X0052 MSSP slave mode with no SS pin control and CKE==1 is ambiguous U2(SLAVE)
2) Data does not show up on PORTB as I intend to. In fact nothing happen to the PORT.
=========SLAVE==========
#include <18F452.h>
PARAMS: none
RETURNS: None
data = spi_read();
if(address >= 0 && address <= 80) // AND operator seems logical here.(atleast to me)
PARAMS: none
while(true)
instr = spi_read();
if (instr == 0x18)
write_data();
=====================Master================
#include <18F452.h>
byte value;
SET_TRIS_B(0); // make PORTB all outputs.
PORTB=0;
address=1;
value=35;
init_ext_eeprom();
do
PORTB=0;
WRITE_EXT_EEPROM( address, value );
PORTB=READ_EXT_EEPROM(address);
} while (TRUE);
==========9365SPI.C=========
#define EEPROM_SELECT PIN_B0
#define EEPROM_DI PIN_C5
#define EEPROM_DO PIN_C4
#define EEPROM_CLK PIN_C3
#define EEPROM_ADDRESS BYTE
#define EEPROM_SIZE 256
void init_ext_eeprom()
short int i;
output_low(EEPROM_DI);
output_low(EEPROM_CLK);
output_low(EEPROM_SELECT);
i=input(EEPROM_DO);
setup_spi(SPI_MASTER | SPI_H_TO_L | SPI_CLK_DIV_16);
output_high(EEPROM_SELECT);
spi_write(0x9);
spi_write(0x80);
void write_ext_eeprom(EEPROM_ADDRESS address, BYTE data)
spi_write(0xa);
spi_write(address);
spi_write(data);
delay_ms(11);
BYTE read_ext_eeprom(EEPROM_ADDRESS address)
BYTE data;
spi_write(0x18);
spi_write(address);
data=spi_read(0);
return(data);
