Data storage by SPI on 18F452s
AdamkT1
PostPosted: Mon May 21, 2007 8:25 pm     Reply with quote
Friends,
I am trying to save data in the EPROM memory of 18f452. The code is very simple which I copied from CCS examples.
One 18F452 is acting as a master and the other 18F452 is emulating 9356 EPROM.
I am trying to write to an address and then read from the same address.
Later, I would put the data on a port for display/debug purpose.
The problem, I am having in Proteus is the following message.
[PIC18] PC=0X0000 $MCLR$ is Low. Processor is in Reset U2(SLAVE)
[PIC18] PC=0X0000 $MCLR$ is Low. Processor is in Reset U2(MASTER)
Does it mean that I have to power the MCLR pin.
Both the codes, the master/slave is pasted below.
'===============U2(SLAVE)====================
#include <18F452.h>
#use rs232(baud=9600, xmit=PIN_C1, rcv=PIN_C0)
int8 memory[80], data, instr, address;
void write_data(void)
PURPOSE: Reads data from SPI and writes it to memory
PARAMS: none
RETURNS: None
while(!spi_data_is_in());
data = spi_read();
if(address >= 0 || address <= 80)
memory[address] = data;
BYTE read_data(void)
PURPOSE: To read the memory
PARAMS: none
RETURNS: Data stored in memory
return (memory[address]);
PURPOSE: Peripheral Initialization
setup_spi(spi_slave | spi_h_to_l | spi_ss_disabled);
while(true)
instr = spi_read();
address = spi_read();
if (instr == 0x18)
instr = spi_read(memory[address]);
else if(instr == 0xa)
write_data();
'==============U1(Master)==========================
#include <18F452.h>
#use rs232(baud=9600, xmit=PIN_A0, rcv=PIN_A1)
#include <9356spi.c>
BYTE PORT_A;
int8 value;
EEPROM_ADDRESS address;
address=1;
init_ext_eeprom();
do
WRITE_EXT_EEPROM( address, 35 );
value=READ_EXT_EEPROM( address );
PORT_A=value;
PORT_A=0;
} while (TRUE);
'======================Code End==================
Thanks.
PostPosted: Tue May 22, 2007 1:01 am     Reply with quote
When posting code please use the 'code' buttons to preserve formatting.
Use the search function of this forum and type 'proteus MCLR', select the 'search for all terms'option. This will give you 5 hits. Read http://www.ccsinfo.com/forum/viewtopic.php?t=28419&highlight=proteus+mclr
Short: Yes, you have to connect MCLR to the positive power supply.
Your check for memory buffer overflow is incorrect.
Change this to
if(address >= 0 || address < 80)
AdamkT1
SPI between two 18F452
PostPosted: Wed May 23, 2007 9:16 am     Reply with quote
Hi friends,
Still having troubles with SPI between two 18F452s. The slave is emulating 9356 EEPROM.
Below is the modified code. I hope somebody would help me solve this problem.
The error(s):
1) In Proteus, the error is : [PIC18 MSSP] PC=0X0052 MSSP slave mode with no SS pin control and CKE==1 is ambiguous U2(SLAVE)
2) Data does not show up on PORTB as I intend to. In fact nothing happen to the PORT.
=========SLAVE==========
#include <18F452.h>
PARAMS: none
RETURNS: None
   data = spi_read();
   if(address >= 0 && address <= 80) // AND operator seems logical here.(atleast to me)
PARAMS: none
   while(true)
      instr = spi_read();
      if (instr == 0x18)
         write_data();
=====================Master================
#include <18F452.h>
   byte value;
   SET_TRIS_B(0); // make PORTB all outputs.
   PORTB=0;
   address=1;
   value=35;
   init_ext_eeprom();
   do
         PORTB=0;
         WRITE_EXT_EEPROM( address, value );
         PORTB=READ_EXT_EEPROM(address);
   } while (TRUE);
==========9365SPI.C=========
#define EEPROM_SELECT PIN_B0
#define EEPROM_DI     PIN_C5
#define EEPROM_DO     PIN_C4
#define EEPROM_CLK    PIN_C3
#define EEPROM_ADDRESS BYTE
#define EEPROM_SIZE    256
void init_ext_eeprom()
   short int i;
   output_low(EEPROM_DI);
   output_low(EEPROM_CLK);
   output_low(EEPROM_SELECT);
   i=input(EEPROM_DO);
   setup_spi(SPI_MASTER | SPI_H_TO_L | SPI_CLK_DIV_16);
   output_high(EEPROM_SELECT);
   spi_write(0x9);
   spi_write(0x80);
void write_ext_eeprom(EEPROM_ADDRESS address, BYTE data)
   spi_write(0xa);
   spi_write(address);
   spi_write(data);
   delay_ms(11);
BYTE read_ext_eeprom(EEPROM_ADDRESS address)
   BYTE data;
   spi_write(0x18);
   spi_write(address);
   data=spi_read(0);
   return(data);
