int EEPROM problems
Jerry R
int EEPROM problems
PostPosted: Mon May 21, 2007 9:39 am     Reply with quote
Wow, this seems basic, but I can't see what's wrong.
I can't seem to write to internal EEPROM in my target 16F874A using the attached code segment. I've successfuly written to internal EEPROM using similar code in past projects. Here's the code:
//Store readibg just made into ext EEPROM=======================================
Store_Reading()
Int_EE_Adr =20;
Int_EE_Data =33;
write_eeprom (Int_EE_Adr , Int_EE_Data);
Delay_ms(100);
Int_EE_Data = 0;
Int_EE_Data = read_eeprom (Int_EE_Adr);
Delay_ms(100);
Both variables in the above code are defined globally as:
unsigned char Int_EE_Adr,Int_EE_Data; //address and data
The subroutine is called from the Main as:
Main()
while (1) //Loop forever
Store_Reading();
Wasted a couple of days on troubleshooting this. ANy help is appreciated!
PostPosted: Mon May 21, 2007 11:52 am     Reply with quote
Try the test program shown in this post:
http://www.ccsinfo.com/forum/viewtopic.php?t=17590&start=1
If you've been testing internal eeprom in a loop for two days, and if
at some point you didn't have the 100 ms delays, you may have burned
up your internal eeprom (at least at certain addresses). There have
been threads on this. Here is one of them:
http://www.ccsinfo.com/forum/viewtopic.php?t=26937&highlight=eeprom+burned
