Wow, this seems basic, but I can't see what's wrong.
I can't seem to write to internal EEPROM in my target 16F874A using the attached code segment. I've successfuly written to internal EEPROM using similar code in past projects. Here's the code:
//Store readibg just made into ext EEPROM=======================================
If you've been testing internal eeprom in a loop for two days, and if
at some point you didn't have the 100 ms delays, you may have burned
up your internal eeprom (at least at certain addresses). There have
been threads on this. Here is one of them:
http://www.ccsinfo.com/forum/viewtopic.php?t=26937&highlight=eeprom+burned
