Microchip IDE Compile Result Question
chargedneuron
View user's profile Send private message Visit poster's website AIM Address
PostPosted: Sat May 05, 2007 6:11 pm     Reply with quote
Greetings all!
I have written a test program to try to understand this question better. I just cant seem to figure out what the compiler is telling me.
#include <16F74.h>
#device *=16
#fuses HS,NOWDT,NOPROTECT
int8   Test1[96];
int8   Test2[90];
   while(true);
With the result...
Memory usage: ROM=0% RAM=99% - 99%
I know I am using all of the available memory. Why does the compiler have a '-99%'? As a result my 'Memory Usage Gauge' shows only 1 byte used.
My thanks in advance for your assistance!
Cheers!
JMc
"Trouble? I call it sport!" - Hyde - The League of Extraordinary Gentlemen
PostPosted: Sat May 05, 2007 10:14 pm     Reply with quote
I never look at the stats in the Output Window. Look at the .LST file
instead. The .LST file has the stats right at the top of the file and
they're in a better format. Example:
Filename: pcm_test.lst
               ROM used: 14 words (0%)
                         Largest free fragment is 2048
               RAM used: 191 (99%) at main() level
                         191 (99%) worst case
               Stack:    0 locations
chargedneuron
PostPosted: Wed May 09, 2007 10:02 pm     Reply with quote
Thanks for the suggestion. That seems to work. too bad the gauge doesn't... I am sure that it has been reported as a bug.
Many Thanks!
