I know I am using all of the available memory. Why does the compiler have a '-99%'? As a result my 'Memory Usage Gauge' shows only 1 byte used.
My thanks in advance for your assistance!
Cheers!
JMc _________________ "Trouble? I call it sport!" - Hyde - The League of Extraordinary Gentlemen
Posted: Sat May 05, 2007 10:14 pm
I never look at the stats in the Output Window. Look at the .LST file
instead. The .LST file has the stats right at the top of the file and
they're in a better format. Example:
Filename: pcm_test.lst
ROM used: 14 words (0%)
Largest free fragment is 2048
RAM used: 191 (99%) at main() level
191 (99%) worst case
Stack: 0 locations
chargedneuron
Joined: 05 May 2007 Posts: 6 Location: Springfield, Oregon, USA
Posted: Wed May 09, 2007 10:02 pm
Thanks for the suggestion. That seems to work. too bad the gauge doesn't... I am sure that it has been reported as a bug.
Many Thanks! _________________ "Trouble? I call it sport!" - Hyde - The League of Extraordinary Gentlemen
