Need a simple PIC code urgently... please help
Mishswati
PostPosted: Wed May 09, 2007 7:17 am     Reply with quote
hi all...
I need a code to generate a pwm output from my PIC micro controller, the one m using is PIC16F877A,The PWM duty cycle should keep varying based on few conditions. the conditions i'll put on my own, just if I can get a code outline....
Also i need an interfacing program . I need to interface 2 things, one is a RPM sensor, which gives continuous pulses as output. These pulses need to be counted.
Another sensor which just gives an output voltage in the range of 4 volts has to be read into any port pin... basically port A...
Please help me out wid de codes... need it urgently.. Sad
PostPosted: Wed May 09, 2007 11:45 am     Reply with quote
Here are some example programs that are in the forum archives.
I need a code to generate a pwm output from my PIC micro controller.
http://www.ccsinfo.com/forum/viewtopic.php?t=23149&start=6
This one doesn't count pulses. It uses CCP to count time between pulses
and converts that to a frequency.
http://www.ccsinfo.com/forum/viewtopic.php?t=29963
http://www.ccsinfo.com/forum/viewtopic.php?t=28842&start=7
jds-pic
PostPosted: Wed May 09, 2007 1:15 pm     Reply with quote
where were you 20 years ago when i needed help with my undergrad assignments? Very Happy Very Happy Very Happy
jds-pic
