I need a code to generate a pwm output from my PIC micro controller, the one m using is PIC16F877A,The PWM duty cycle should keep varying based on few conditions. the conditions i'll put on my own, just if I can get a code outline....
Also i need an interfacing program . I need to interface 2 things, one is a RPM sensor, which gives continuous pulses as output. These pulses need to be counted.
Another sensor which just gives an output voltage in the range of 4 volts has to be read into any port pin... basically port A...
Please help me out wid de codes... need it urgently..
Posted: Wed May 09, 2007 11:45 am
Here are some example programs that are in the forum archives.
I need a code to generate a pwm output from my PIC micro controller.
