USB PIC18f2550 problem
bercam
PostPosted: Wed May 02, 2007 11:57 am     Reply with quote
Hi all,
I'm trying to run the USB CDC code downloaded from CCS web page.
I've got my own board using PIC18f2550.
The board is running with 4Mhz Xtall:
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,DEBUG,USBDIV,PLL1, CPUDIV1,VREGEN
#use delay(clock=48000000)
I'm using USART serial port to debug code
#use rs232(STREAM=CH1,baud=19200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
I've put a 470nF on C3 and 47KOhm resistor between VCC_USB and D+ in order to select Hi-Speed USB peripheral
My board gets power from USB port and after plug it into USB conector I can see messages in the hyperterminal session (The board is running). At same time Windows recognize a new peripheral and show me a window in order to select .inf driver file .
After that I select the follow path C:\MCHPFSUSB\fw\CDC\inf\win2k_winxp
At the end Windows could not install the hardware: wizard could not find a suitable software
any suggestion
kevcon
PostPosted: Wed May 02, 2007 12:06 pm     Reply with quote
Double check the data sheet for the resistor value on D+, all of the specs I've seen use a 1.5K resistor.
bertronicom
View user's profile Send private message Send e-mail MSN Messenger
it works fine now
PostPosted: Mon May 07, 2007 9:44 am     Reply with quote
finally it works the problem was:
I've selecting .inf from Microchip instead .inf CCS
PostPosted: Tue May 08, 2007 5:40 am     Reply with quote
anyway you dont need to use any external resistor since pull-up resistors are inside a PIC.
