bercam Guest
| USB PIC18f2550 problem |
Posted: Wed May 02, 2007 11:57 am |
Hi all,
I'm trying to run the USB CDC code downloaded from CCS web page.
I've got my own board using PIC18f2550.
The board is running with 4Mhz Xtall:
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,DEBUG,USBDIV,PLL1, CPUDIV1,VREGEN
#use delay(clock=48000000)
I'm using USART serial port to debug code
#use rs232(STREAM=CH1,baud=19200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
I've put a 470nF on C3 and 47KOhm resistor between VCC_USB and D+ in order to select Hi-Speed USB peripheral
My board gets power from USB port and after plug it into USB conector I can see messages in the hyperterminal session (The board is running). At same time Windows recognize a new peripheral and show me a window in order to select .inf driver file .
After that I select the follow path C:\MCHPFSUSB\fw\CDC\inf\win2k_winxp
At the end Windows could not install the hardware: wizard could not find a suitable software
any suggestion |
kevcon
Joined: 21 Feb 2007 Posts: 142 Location: Michigan, USA
Posted: Wed May 02, 2007 12:06 pm |
| Double check the data sheet for the resistor value on D+, all of the specs I've seen use a 1.5K resistor. |
bertronicom
Joined: 17 Nov 2004 Posts: 26 Location: University of Cantabria -SPAIN
| it works fine now |
Posted: Mon May 07, 2007 9:44 am |
finally it works the problem was:
I've selecting .inf from Microchip instead .inf CCS |
Posted: Tue May 08, 2007 5:40 am |
| anyway you dont need to use any external resistor since pull-up resistors are inside a PIC. |
