Search for these keywords: LEDs timer
Set it to: Search for All Terms
The reason for using those keywords is because you want information
about blinking more than one LED, so you use the plural form (LEDs).
Then, because you want slow speed blinking, it's likely that you
want to use the timer to do this. Result:
http://www.ccsinfo.com/forum/viewtopic.php?t=23920&highlight=leds+timer
dacenrie
Posted: Tue May 01, 2007 6:51 pm
Thanks for the quick response and my apologies for not taking advantage of the search engine. Your help was much appreciated.
