Pulse Problem!!!
dacenrie
Pulse Problem!!!
PostPosted: Tue May 01, 2007 5:08 pm     Reply with quote
What's the best way to pulse an LED every 1/2 second WITHOUT using the PWM module???
Also, what if I have multiple LEDs that each have different pulse requirements and CANNOT use the PWM module???
I'm assuming that timers will be an important factor here. Anyway, help me out!!!
Thanks!
PostPosted: Tue May 01, 2007 6:31 pm     Reply with quote
Use the forum's search page:
http://www.ccsinfo.com/forum/search.php
Search for these keywords: LEDs timer
Set it to: Search for All Terms
The reason for using those keywords is because you want information
about blinking more than one LED, so you use the plural form (LEDs).
Then, because you want slow speed blinking, it's likely that you
want to use the timer to do this. Result:
http://www.ccsinfo.com/forum/viewtopic.php?t=23920&highlight=leds+timer
dacenrie
PostPosted: Tue May 01, 2007 6:51 pm     Reply with quote
Thanks for the quick response and my apologies for not taking advantage of the search engine. Your help was much appreciated.
