I got some problems of expander MCP23S08:
Two input signals at IO_0 and IO_1, waht i desired is negtive edge of IO_0 siganl or toggled IO_1 signal will triggle the INT, however, IO_0 will make the INT get low, but it won't nolonger rise even i've read the register INTCAP and GPIO that is supposed to be able to clear the INT signal.
