32Bit preprocessor calculation
TelemitryT
PostPosted: Mon Apr 16, 2007 8:55 am     Reply with quote
Hello
Has anybody some experience with perprocessor calculations?
Because of a user friendly handling I need some unique calculations. It is necessary to do them with the preprocessor because I work with a Pic10F202 and with 512k ROM I've not enough memory left to do them in the program.
Me problem is now the calculation returns a 16Bit value but the real result is a 24Bit (32 Bit) Value. Is there a possibility to tell the compiler to calculate with 32 Bit values?
Piece code:
#define     RUN_TIME        1       //Set Run Time in d (0 - 814) (resolution 2.304s)
#define c_RUN_TIME         (RUN_TIME*(24*3600*1000000)+128*128/2)/(128*128)   //int32
int32   RH_Counter;    //RunTime and Hipernation Counter
void init(void){
   //Init Timer
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);setup_wdt(WDT_18MS);
   //Init global variables
   RH_Counter = c_RUN_TIME;
If I look into the Lising file. The compiler translated the variable initialisation like this:
....................    //Init global variables
....................    RH_Counter = c_RUN_TIME;
019A:  CLRF   15
019B:  CLRF   14
019C:  MOVLW  77
019D:  MOVWF  13
019E:  MOVLW  5E
019F:  MOVWF  12
He initializes the variable RH_Counter with the Value 0x775E instead with the real result of the calculation above witch is 0x50775E.
Has anybody a idea how to solve this problem?
Thanks for your reply
PostPosted: Mon Apr 16, 2007 11:41 am     Reply with quote
I suggest that you first get it running in MSVC and prove that it works
there. Then move it to CCS.
