Has anybody some experience with perprocessor calculations?
Because of a user friendly handling I need some unique calculations. It is necessary to do them with the preprocessor because I work with a Pic10F202 and with 512k ROM I've not enough memory left to do them in the program.
Me problem is now the calculation returns a 16Bit value but the real result is a 24Bit (32 Bit) Value. Is there a possibility to tell the compiler to calculate with 32 Bit values?
Piece code:
#define RUN_TIME 1 //Set Run Time in d (0 - 814) (resolution 2.304s)
