Hi, I was wondering if it might be possible to set all ANx inputs for analog but still use some for digital input only ?
I have a circuit here that uses AN0,1 for analog input and then RA3,4,5 for digital input. I'm not clear about which constant to use for SETUP_ADC_PORTS().
Posted: Thu Apr 05, 2007 5:36 am
One way around this type of problem is to read the analogue voltage of the digital input, then compare the analogue reading with the expected equivalent logic high/low digital value.
