PIC16F877 Analog/Digital Inputs
DonWare
PostPosted: Wed Apr 04, 2007 1:13 pm     Reply with quote
Hi, I was wondering if it might be possible to set all ANx inputs for analog but still use some for digital input only ?
I have a circuit here that uses AN0,1 for analog input and then RA3,4,5 for digital input. I'm not clear about which constant to use for SETUP_ADC_PORTS().
I'd appreciate any ideas.
Thanks. Don
PostPosted: Wed Apr 04, 2007 1:42 pm     Reply with quote
Only certain combinations of analog and digital pins are allowed by
the PIC hardware. See this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=30320&highlight=analog&start=5
adrian
PostPosted: Thu Apr 05, 2007 5:36 am     Reply with quote
One way around this type of problem is to read the analogue voltage of the digital input, then compare the analogue reading with the expected equivalent logic high/low digital value.
