AD7799 design and sample code
suncq
PostPosted: Tue Apr 03, 2007 9:49 am     Reply with quote
I am doing a weigh scale project using 877 and AD7799( 24-Bit Sigma-Delta ADC ).any body has used the AD7799 and how is the performance and any giude for its design or sample code?
thanks
PostPosted: Tue Apr 03, 2007 12:06 pm     Reply with quote
Someone has posted a driver down at the end of this thread on the AVR
forum:
http://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&t=43894
To convert this driver to CCS, you need a full understanding of
the differences between CCS and other compilers. For example,
in that driver, they declare some variables as 'signed long'.
In CCS, this would become 'signed int32'. Also, CCS has separate
functions for spi_read() and spi_write(). That driver has one combined
function. But you can tell from the context, which commands are
doing read operations and which ones are doing writes.
I don't want to convert the driver for you. You must do it.
suncq
Thanks for you quick reply!
PostPosted: Wed Apr 04, 2007 6:40 am     Reply with quote
Thanks for you quick reply! I will study it later!
