How can I use a 16F648A mcu to read an analog voltage (0 to 5 V range) ?
The 16F648A does not have a ADC, but it has a comparator. Also mention what the accuracy of the result would be ???
thanks
arunb
libor
Posted: Thu Mar 22, 2007 11:02 am
Using another port of the PIC as an output you can charge/discharge an RC element that is connected to the comparator's first input. The timepoint, the comparators triggers corresponds to the analog voltage on the second input of the comparator.
Accuracy: depends on how slow is your RC element, this also affects the 'sampling frequency'.
Posted: Fri Mar 23, 2007 12:26 pm
The 16F648A does not have a ADC , but it has a comparator.
