Reading an analog voltage with a digital input
arunb
PostPosted: Thu Mar 22, 2007 9:25 am     Reply with quote
How can I use a 16F648A mcu to read an analog voltage (0 to 5 V range) ?
The 16F648A does not have a ADC, but it has a comparator. Also mention what the accuracy of the result would be ???
thanks
arunb
libor
PostPosted: Thu Mar 22, 2007 11:02 am     Reply with quote
Using another port of the PIC as an output you can charge/discharge an RC element that is connected to the comparator's first input. The timepoint, the comparators triggers corresponds to the analog voltage on the second input of the comparator.
Accuracy: depends on how slow is your RC element, this also affects the 'sampling frequency'.
PostPosted: Fri Mar 23, 2007 12:26 pm     Reply with quote
The 16F648A does not have a ADC , but it has a comparator.
This project may help:
http://web.archive.org/web/20060427170840/http://www.cappels.org/dproj/wfc/wfc.html
Mark
PostPosted: Sun Mar 25, 2007 8:57 am     Reply with quote
For slope
ww1.microchip.com/downloads/en/AppNotes/00863a.pdf
For delta
ww1.microchip.com/downloads/en/AppNotes/00700a.pdf
