micman2
structure BUG ?? |
Posted: Mon Mar 12, 2007 10:05 am |
I have created a structure, I have defined in the header file but when I make the debug, the structure is incomplete??
Why?
![](http://img101.imageshack.us/img101/3793/mwsnapyi0.gif) |
kevcon
Joined: 21 Feb 2007 Posts: 142 Location: Michigan, USA
Posted: Mon Mar 12, 2007 11:20 am |
What version CCS are you using? |
Posted: Mon Mar 12, 2007 11:35 am |
kevcon wrote: | What version CCS are you using? |
4.012 |
kevcon
Posted: Mon Mar 12, 2007 11:47 am |
I’m using 4.027 and get the same results.
I did some experimenting and CCS seems to have a problem with multidimensional arrays in structures.
It looks like it ignores anything that comes after one. |
karth
Posted: Mon Mar 12, 2007 11:56 am |
here is sample of the code i am using take a look at it ...
static struct DATAREC // periodic data record definition
int8 rec_epl;
int8 rec_stat;
int8 rec_battinput[2];
int8 rec_speed[2];
int8 rec_course[2];
int8 rec_lat[4];
int8 rec_lon[5];
int8 rec_utc[3];
int8 rec_date[3];
static struct DATAREC pdr; |
