structure BUG ??
micman2
structure BUG ??
PostPosted: Mon Mar 12, 2007 10:05 am     Reply with quote
I have created a structure, I have defined in the header file but when I make the debug, the structure is incomplete??
Why?
kevcon
PostPosted: Mon Mar 12, 2007 11:20 am     Reply with quote
What version CCS are you using?
PostPosted: Mon Mar 12, 2007 11:35 am     Reply with quote
4.012
kevcon
PostPosted: Mon Mar 12, 2007 11:47 am     Reply with quote
I’m using 4.027 and get the same results.
I did some experimenting and CCS seems to have a problem with multidimensional arrays in structures.
It looks like it ignores anything that comes after one.
karth
PostPosted: Mon Mar 12, 2007 11:56 am     Reply with quote
here is sample of the code i am using take a look at it ...
static struct DATAREC // periodic data record definition
int8 rec_epl;
int8 rec_stat;
int8 rec_battinput[2];
int8 rec_speed[2];
int8 rec_course[2];
int8 rec_lat[4];
int8 rec_lon[5];
int8 rec_utc[3];
int8 rec_date[3];
static struct DATAREC pdr;
