Knight_FlyCn
Error with 18F4620: Expecting a structure/union |
Posted: Fri May 10, 2013 11:00 am |
Code: | /* _CPUDIV_OSC1_PLL2_1L, // Divide clock by 2
_FOSC_HS_1H, // Select High Speed (HS) oscillator
_WDT_OFF_2H, // Watchdog Timer off
MCLRE_ON_3H // Master Clear on
#include <RFD.h>
#include "def_18f4620.c"
#include "slave_1_tx_rx.h"
// Xac dinh ----
#define SPI_MODE_0 (SPI_L_TO_H | SPI_XMIT_L_TO_H)
// Them vao
#ifndef FREQ
#define FREQ 4000000
#ifndef baud
#define baud 96000
#define spbrg_value (((FREQ/64)/baud)-1)
#bit CS = 0xF80.4
#bit RST = 0xF82.2
#bit INT_ = 0xF81.0
#bit WAKE = 0xF82.1
#bit CS_Direction = 0xF92.4
#bit RST_Direction = 0xF94.2
#bit INT_Direction = 0xF93.0
#bit WAKE_Direction = 0xF94.1
// Command: 0x00: IP request //
// 0x01: I_AM_LM35 //
// 0x02: I_AM_PIR
INT TEMP;
int adress;
INT VALUE;
INT16 k=0;
const int IP_request=0x00,adress_surport=0x01,ip_surport=0x10;
int I_AM_LM35=0x01;
INT DATA_SEND=0X02;
INT COMMAND;//
INT1 IP_REQUEST_FLAG=FALSE;
SHORT SLEEP_MODE=true;
//!#INT_RTCC
//!VOID NGAT_TIMER0()
//!{ printf("ngat timer0!");
//! IF (k>= 1000)
//! k=0;
//! SLEEP_MODE=FALSE;
//! TMR0IF=0;
//! disable_interrupts(INT_TIMER0);
#INT_EXT
void ngat_RB0()
temp = read_ZIGBEE_short(INTSTAT); // Read and flush register INTSTAT
if ((temp&(1<<3))==(1<<3))
read_RX_FIFO();
COMMAND =DATA_RX[0];
SWITCH (COMMAND)
CASE ip_surport:
ADRESS=DATA_RX[1];
rfd_ADDRESS_short[1]=adress;
IP_REQUEST_FLAG=TRUE;
BREAK;
TRISB1=TRISB2=TRISB3=1;
TRISC0=TRISD3=0;
CS_Direction = 0; // Set direction to be output
RST_Direction = 0; // Set direction to be output
INT_Direction = 1; // Set direction to be input
WAKE_Direction = 0; // Set direction to be output
Delay_ms(5);
setup_spi(SPI_MASTER | SPI_MODE_0 | SPI_CLK_DIV_4); // Initialize SPI module
pin_reset(); // Activate reset from pin
software_reset(); // Activate software reset
RF_reset(); // RF reset
set_WAKE_from_pin(); // Set wake from pin
set_long_address(ADDRESS_long_1);
set_short_address(rfd_ADDRESS_short); // Set short address
set_PAN_ID(PAN_ID); // Set PAN_ID
init_ZIGBEE_nonbeacon(); // Initialize ZigBee module
nonbeacon_device();
set_TX_power(31); // Set max TX power
set_frame_format_filter(1); // 1 all frames, 3 data frame only
set_reception_mode(1); // 1 normal mode
enable_int();
pin_wake(); // Wake from pin
//enable interrupt ext
enable_interrupts(INT_EXT);
ext_int_edge(H_to_L);
// gioi thieu
printf("****************************************\r\n");
Printf(" ");
Printf(" RFD_designed by Huynh Thanh Dien\r\n");
Printf(" ");
// IP request
printf(" Requesting IP...\r\n");
PAN_ID_destination[0] = PAN_ID[0];
PAN_ID_destination[1] = PAN_ID[1];
address_short_destination[0] = coord_address_short[0];
address_short_destination[1] = coord_address_short[1];
PAN_ID_source[0] = PAN_ID[0];
PAN_ID_source[1] = PAN_ID[1];
address_short_source[0] = rfd_address_short[0];
address_short_source[1] = rfd_address_short[1];
DATA_TX[0]=Ip_request;
DATA_TX[1]=0X00;
write_TX_normal_FIFO();
WHILE (!IP_REQUEST_FLAG){}
PRINTF(" IP REQUEST SUCCESSED!\r\n");
PRINTF(" MY IP_ADRESS IS: 0x0%D\r\n",ADRESS);
DATA_TX[0]=I_AM_LM35;
DATA_TX[1]=0X00;
//SETUP ADC
setup_adc_ports( ALL_ANALOG );
setup_adc(ADC_CLOCK_INTERNAL );
set_adc_channel( 0 );
while (1)
value = read_adc();
VALUE=VALUE*360/1023;
PRINTF(" NHIET DO: %D\r\n",VALUE);
DATA_TX[0]=DATA_SEND;
DATA_TX[1]=VALUE;
//! IF (SLEEP_MODE)
//! printf(" Sleeping...");
//! SLEEP_MODE=TRUE;
//! sleep();
When I add:
SPBRG=spbrg_value; // Fill SPBRG register to set the baud rate
RCSTA.SPEN=1; // To activate serial port (Tx and Rx pins)
RCSTA.CREN=1; // To enable continuous reception
PIE1.RCIE=1; // To enable the Reception (Rx) Interrupt
INTCON.GIE=1;
INTCON.PEIE=1; |
CCS 4.1 errors : "Expecting a structure/union"
Who can help me repair it. _________________ Thinh |
Knight_FlyCn
Posted: Fri May 10, 2013 11:51 am |
I success
#include <RFD.h>
// Xac dinh ----
// Them vao
#ifndef FREQ
#ifndef baud
#define baud 96000
#bit CS = 0xF80.4
#bit RST = 0xF82.2
#bit INT_ = 0xF81.0
#bit WAKE = 0xF82.1
// 0x02: I_AM_PIR
INT TEMP;
int adress;
INT VALUE;
INT16 k=0;
int I_AM_LM35=0x01;
INT DATA_SEND=0X02;
INT COMMAND;//
// Them vao
unsigned char card_id[10];
unsigned int i=0,pos;
//!#INT_RTCC
//! IF (k>= 1000)
//! k=0;
//! TMR0IF=0;
#INT_EXT
void ngat_RB0()
read_RX_FIFO();
SWITCH (COMMAND)
CASE ip_surport:
ADRESS=DATA_RX[1];
BREAK;
void interrupt()
card_id[i]=RCREG; // Store the received data byte by byte
i++;
TRISC0=TRISD3=0;
Delay_ms(5);
nonbeacon_device();
enable_int();
// gioi thieu
Printf(" ");
Printf(" ");
// IP request
DATA_TX[1]=0X00;
DATA_TX[1]=0X00;
// SET RX VA TX
GIE=1;
PEIE=1;
while (1)
interrupt();
PRINTF(" MA SO THE: %D\r\n",card_id[10]);
DATA_TX[1]=card_id[10];
//! IF (SLEEP_MODE)
//! sleep();
Compile success
People watching and commenting. RX pins of the 18F4620 connected to the RFID reader and read key tag . Save to "ard_id". And sent to the ZigBee module _________________ Thinh |
senur
Posted: Wed Dec 11, 2013 9:33 am |
I'm facing the same problem. May I know what you did? |
