Error with 18F4620: Expecting a structure/union
Knight_FlyCn
PostPosted: Fri May 10, 2013 11:00 am     Reply with quote
/* _CPUDIV_OSC1_PLL2_1L,  // Divide clock by 2
   _FOSC_HS_1H,           // Select High Speed (HS) oscillator
   _WDT_OFF_2H,           // Watchdog Timer off
   MCLRE_ON_3H            // Master Clear on
#include <RFD.h>
#include "def_18f4620.c"
#include "slave_1_tx_rx.h"
// Xac dinh ----
#define SPI_MODE_0  (SPI_L_TO_H | SPI_XMIT_L_TO_H)
// Them vao
#ifndef FREQ
#define FREQ 4000000
#ifndef baud
#define baud 96000
#define spbrg_value (((FREQ/64)/baud)-1)
#bit CS     = 0xF80.4
#bit RST    = 0xF82.2
#bit INT_   = 0xF81.0
#bit WAKE   = 0xF82.1
#bit CS_Direction    = 0xF92.4
#bit RST_Direction   = 0xF94.2
#bit INT_Direction   = 0xF93.0
#bit WAKE_Direction  = 0xF94.1
// Command: 0x00: IP request                                                  //
//          0x01: I_AM_LM35                                                   //
//          0x02: I_AM_PIR
INT TEMP;
int adress;
INT VALUE;
INT16 k=0;
const int IP_request=0x00,adress_surport=0x01,ip_surport=0x10;
int I_AM_LM35=0x01;
INT DATA_SEND=0X02;
INT COMMAND;//
INT1 IP_REQUEST_FLAG=FALSE;
SHORT SLEEP_MODE=true;
//!#INT_RTCC
//!VOID NGAT_TIMER0()
//!{  printf("ngat timer0!");
//!   IF (k>= 1000)
//!   k=0;
//!   SLEEP_MODE=FALSE;
//!   TMR0IF=0;
//!   disable_interrupts(INT_TIMER0);
#INT_EXT
void ngat_RB0()
   temp = read_ZIGBEE_short(INTSTAT); // Read and flush register INTSTAT
   if ((temp&(1<<3))==(1<<3))
      read_RX_FIFO();
      COMMAND =DATA_RX[0];
      SWITCH (COMMAND)
      CASE ip_surport:
                  ADRESS=DATA_RX[1];
                  rfd_ADDRESS_short[1]=adress;
                  IP_REQUEST_FLAG=TRUE;
      BREAK;
   TRISB1=TRISB2=TRISB3=1;
   TRISC0=TRISD3=0;
    CS_Direction   = 0;     // Set direction to be output
   RST_Direction  = 0;     // Set direction to be output
   INT_Direction  = 1;     // Set direction to be input
   WAKE_Direction = 0;     // Set direction to be output
   Delay_ms(5);
   setup_spi(SPI_MASTER | SPI_MODE_0 | SPI_CLK_DIV_4);  // Initialize SPI module
   pin_reset();                              // Activate reset from pin
   software_reset();                         // Activate software reset
   RF_reset();                               // RF reset
   set_WAKE_from_pin();                      // Set wake from pin
   set_long_address(ADDRESS_long_1);
   set_short_address(rfd_ADDRESS_short);       // Set short address
   set_PAN_ID(PAN_ID);                     // Set PAN_ID
   init_ZIGBEE_nonbeacon();                  // Initialize ZigBee module
   nonbeacon_device();
   set_TX_power(31);                         // Set max TX power
   set_frame_format_filter(1);               // 1 all frames, 3 data frame only
   set_reception_mode(1);                    // 1 normal mode
   enable_int();
   pin_wake(); // Wake from pin
   //enable interrupt ext
   enable_interrupts(INT_EXT);
   ext_int_edge(H_to_L);
   // gioi thieu
   printf("****************************************\r\n");
   Printf("        ");
   Printf("    RFD_designed by Huynh Thanh Dien\r\n");
   Printf("        ");
   // IP request
   printf(" Requesting IP...\r\n");
   PAN_ID_destination[0] = PAN_ID[0];
   PAN_ID_destination[1] = PAN_ID[1];
   address_short_destination[0] = coord_address_short[0];
   address_short_destination[1] = coord_address_short[1];
         PAN_ID_source[0] = PAN_ID[0];
         PAN_ID_source[1] = PAN_ID[1];
         address_short_source[0] = rfd_address_short[0];
         address_short_source[1] = rfd_address_short[1];
         DATA_TX[0]=Ip_request;
      DATA_TX[1]=0X00;
      write_TX_normal_FIFO();
  WHILE (!IP_REQUEST_FLAG){}
   PRINTF(" IP REQUEST SUCCESSED!\r\n");
   PRINTF(" MY IP_ADRESS IS: 0x0%D\r\n",ADRESS);
   DATA_TX[0]=I_AM_LM35;
   DATA_TX[1]=0X00;
   //SETUP ADC
   setup_adc_ports( ALL_ANALOG );
   setup_adc(ADC_CLOCK_INTERNAL );
   set_adc_channel( 0 );
   while (1)
       value = read_adc();
       VALUE=VALUE*360/1023;
       PRINTF(" NHIET DO: %D\r\n",VALUE);
       DATA_TX[0]=DATA_SEND;
      DATA_TX[1]=VALUE;
//!      IF (SLEEP_MODE)
//!      printf(" Sleeping...");
//!      SLEEP_MODE=TRUE;
//!      sleep();
When I add:
SPBRG=spbrg_value;      // Fill SPBRG register to set the baud rate
   RCSTA.SPEN=1;         // To activate serial port (Tx and Rx pins)
   RCSTA.CREN=1;         // To enable continuous reception
   PIE1.RCIE=1;         // To enable the Reception (Rx) Interrupt
   INTCON.GIE=1;
   INTCON.PEIE=1;
CCS 4.1 errors : "Expecting a structure/union"
Who can help me repair it.
Thinh
Knight_FlyCn
PostPosted: Fri May 10, 2013 11:51 am     Reply with quote
I success
#include <RFD.h>
// Xac dinh ----
// Them vao
#ifndef FREQ
#ifndef baud
#define baud 96000
#bit CS     = 0xF80.4
#bit RST    = 0xF82.2
#bit INT_   = 0xF81.0
#bit WAKE   = 0xF82.1
//          0x02: I_AM_PIR
INT TEMP;
int adress;
INT VALUE;
INT16 k=0;
int I_AM_LM35=0x01;
INT DATA_SEND=0X02;
INT COMMAND;//
// Them vao
unsigned char card_id[10];
unsigned int i=0,pos;
//!#INT_RTCC
//!   IF (k>= 1000)
//!   k=0;
//!   TMR0IF=0;
#INT_EXT
void ngat_RB0()
      read_RX_FIFO();
      SWITCH (COMMAND)
      CASE ip_surport:
                  ADRESS=DATA_RX[1];
      BREAK;
void interrupt()
   card_id[i]=RCREG;      // Store the received data byte by byte
   i++;
   TRISC0=TRISD3=0;
   Delay_ms(5);
   nonbeacon_device();
   enable_int();
   // gioi thieu
   Printf("        ");
   Printf("        ");
   // IP request
      DATA_TX[1]=0X00;
   DATA_TX[1]=0X00;
   // SET RX VA TX
   GIE=1;
   PEIE=1;
   while (1)
      interrupt();
       PRINTF(" MA SO THE: %D\r\n",card_id[10]);
      DATA_TX[1]=card_id[10];
//!      IF (SLEEP_MODE)
//!      sleep();
Compile success
People watching and commenting. RX pins of the 18F4620 connected to the RFID reader and read key tag . Save to "ard_id". And sent to the ZigBee module
Thinh
senur
PostPosted: Wed Dec 11, 2013 9:33 am     Reply with quote
I'm facing the same problem. May I know what you did?
