| View previous topic :: View next topic   |
			deepakomanna
				| prescaler of timer0 becomes zero ? |
				 Posted: Thu Mar 08, 2007 10:34 pm     |
				hi,
i am using MPLAB V7.5 & CCS PCM C Compiler, Version 3.249, 34534.
i am facing one problem plz let me soluton over it, the problem is,
SETUP_TIMER_0(RTCC_DIV_64);     // prescaler 1:64
SETUP_TIMER_0(RTCC_INTERNAL);  // start timer0
by doing this,the prescler bits PS0:PS2 Becomes zero.
plz tell me what should i to do ? |
				 Posted: Thu Mar 08, 2007 10:49 pm     |
				Do this:
 	  | Code: | 	 		  | SETUP_TIMER_0(RTCC_INTERNAL | RTCC_DIV_64); |
It's in the manual. |
			deepakomanna
				| timer0 problem not solved totally ? |
				 Posted: Thu Mar 08, 2007 11:54 pm     |
				 	  | PCM programmer wrote: | 	 		  Do this:
ok, thanks.
but i want to start timer0 after some initialisation
i.e.
main()
..........some variables decleration.............
init_CPU();
.........other function() decleration..........
 .....& here i want to start timer0....
void init_CPU()
...........other initialition.....
#int_timer0
timer0 isr()
