prescaler of timer0 becomes zero ?
deepakomanna
View user's profile Send private message AIM Address Yahoo Messenger
PostPosted: Thu Mar 08, 2007 10:34 pm     Reply with quote
hi,
i am using MPLAB V7.5 & CCS PCM C Compiler, Version 3.249, 34534.
i am facing one problem plz let me soluton over it, the problem is,
SETUP_TIMER_0(RTCC_DIV_64); // prescaler 1:64
SETUP_TIMER_0(RTCC_INTERNAL); // start timer0
Confused
by doing this,the prescler bits PS0:PS2 Becomes zero.
plz tell me what should i to do ?
PostPosted: Thu Mar 08, 2007 10:49 pm     Reply with quote
Do this:
SETUP_TIMER_0(RTCC_INTERNAL | RTCC_DIV_64);
It's in the manual.
deepakomanna
timer0 problem not solved totally ?
PostPosted: Thu Mar 08, 2007 11:54 pm     Reply with quote
PCM programmer wrote:
Do this:
It's in the manual.
ok, thanks.
but i want to start timer0 after some initialisation
i.e.
main()
..........some variables decleration.............
init_CPU();
.........other function() decleration..........
.....& here i want to start timer0....
void init_CPU()
...........other initialition.....
#int_timer0
timer0 isr()
