Interrupt on change constantly triggering.
ch_dupre
PostPosted: Thu Mar 08, 2007 10:05 am     Reply with quote
I'm trying to detect a change on PIN_B4 but the interrupt is constantly triggering.
Can someone point out what I'm doing wrong?
Here is the code:
#include <18F4550.h>
#device adc=10
#IF  getenv("VERSION")>4.001
   #device ANSI
#ENDIF
#FUSES HS                       //High speed Osc (> 4mhz)
#FUSES NOPROTECT                //Code not protected from reading
#FUSES BORV20                   //Brownout reset at 2.0V
#FUSES NOPUT                    //No Power Up Timer
#FUSES NOCPD                    //No EE protection
#FUSES STVREN                   //Stack full/underflow will cause reset
#FUSES NODEBUG                  //No Debug mode for ICD
#FUSES NOWRT                    //Program memory not write protected
#FUSES NOWRTD                   //Data EEPROM not write protected
#FUSES IESO                     //Internal External Switch Over mode enabled
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#FUSES PBADEN                   //PORTB pins are configured as analog input channels on RESET
#FUSES NOWRTC                   //configuration not registers write protected
#FUSES NOWRTB                   //Boot block not write protected
#FUSES NOEBTR                   //Memory not protected from table reads
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES NOCPB                    //No Boot Block code protection
#FUSES MCLR                     //Master Clear pin enabled
#FUSES LPT1OSC                  //Timer1 configured for low-power operation
#FUSES PLL1                     //No PLL PreScaler
#use delay(clock=20000000)
#use rs232(baud=9600,parity=N,xmit=PIN_D0,rcv=PIN_D1,bits=8, invert, STREAM=COM2)
   set_tris_b(0b00010000);
   //output_b(0x10) ;
   enable_interrupts( INT_RB );
   enable_interrupts( GLOBAL );
   while (1)
#INT_RB
void PortBChange_isr( void )
   set_tris_b(0x10);
   input_b();
   fprintf(COM2, "INTERRUPT\n");
I'm using V4.026.
Thanks for your help.
Christophe D.
Humberto
PostPosted: Thu Mar 08, 2007 10:22 am     Reply with quote
Try this way:
int interrupt_RB;
#INT_RB
   input_b();
   interrupt_RB = TRUE;
   set_tris_b(0x10);
   while (1)
       if( interrutp_RB )
           interrupt_RB = FALSE;
Humberto
PostPosted: Thu Mar 08, 2007 10:35 am     Reply with quote
#INT_RB
set_tris_b(0x10);
input_b();
The input_b() function won't actually read the port unless you load
it into a variable. You can see this in the .LST file.
Declare a local variable in that function and do this:
int8 c;
c = input_b();
ch_dupre
PostPosted: Thu Mar 08, 2007 10:37 am     Reply with quote
Thanks Humberto and PCM programmer. Both solutions work.
Christophe D.
