ch_dupre
Interrupt on change constantly triggering. |
Posted: Thu Mar 08, 2007 10:05 am |
I'm trying to detect a change on PIN_B4 but the interrupt is constantly triggering.
Can someone point out what I'm doing wrong?
Here is the code:
#include <18F4550.h>
#device adc=10
#IF getenv("VERSION")>4.001
#device ANSI
#ENDIF
#FUSES HS //High speed Osc (> 4mhz)
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
#FUSES LPT1OSC //Timer1 configured for low-power operation
#FUSES PLL1 //No PLL PreScaler
#use rs232(baud=9600,parity=N,xmit=PIN_D0,rcv=PIN_D1,bits=8, invert, STREAM=COM2)
set_tris_b(0b00010000);
//output_b(0x10) ;
enable_interrupts( INT_RB );
enable_interrupts( GLOBAL );
while (1)
#INT_RB
void PortBChange_isr( void )
set_tris_b(0x10);
input_b();
fprintf(COM2, "INTERRUPT\n");
I'm using V4.026.
Thanks for your help.
Christophe D. |
Humberto
Posted: Thu Mar 08, 2007 10:22 am |
Try this way:
int interrupt_RB;
#INT_RB
input_b();
interrupt_RB = TRUE;
set_tris_b(0x10);
while (1)
if( interrutp_RB )
interrupt_RB = FALSE;
Humberto |
Posted: Thu Mar 08, 2007 10:35 am |
set_tris_b(0x10);
input_b();
The input_b() function won't actually read the port unless you load
it into a variable. You can see this in the .LST file.
Declare a local variable in that function and do this:
int8 c;
c = input_b();
ch_dupre
Posted: Thu Mar 08, 2007 10:37 am |
Thanks Humberto and PCM programmer. Both solutions work.
Christophe D. |
