Corta
Timing problem with PIC18F2620 |
Posted: Thu Jan 25, 2007 11:06 am |
I starting to work with PIC18F2620 and I simply trying to test output port...
setup_spi(FALSE);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
output_bit(PIN_A0, 1);
delay_ms(50000);
output_bit(PIN_A0, 0);
delay_ms(50000);
#include <18F2620.h>
#device ICD=TRUE
#device adc=8
#fuses NOWDT,WDT128,HS, NOPROTECT, NOIESO, NOBROWNOUT, BORV21, NOPUT, NOCPD, STVREN, DEBUG, NOLVP, NOWRT, NOWRTD, NOEBTR, NOCPB, NOEBTRB, NOWRTC, NOWRTB, FCMEN, XINST, NOPBADEN, LPT1OSC, MCLR
I cannot obtain the good delay, I got 2us high and 2us down. I got a 20MHz x-tall. Maybe I've fogot a fuse or something. Anybody can help me on this? |
Posted: Thu Jan 25, 2007 12:04 pm |
delay_ms(50000);
delay_ms(50000);
The delays are too long. Change them both to 500.
Quote: | #include <18F2620.h>
#device ICD=TRUE
#device adc=8
#use delay(clock=20000000) |
CCS doesn't support the Extended Instruction Set. Change the fuse
to NOXINST. |
Corta
Posted: Thu Jan 25, 2007 1:56 pm |
wow it's work!
Thank you very much! |
