		| Author | Message |
		| Corta
				| Timing problem with PIC18F2620 |
				|  Posted: Thu Jan 25, 2007 11:06 am |   |
				| I starting to work with PIC18F2620 and I simply trying to test output port...
 setup_spi(FALSE);
 setup_wdt(WDT_OFF);
 setup_timer_0(RTCC_INTERNAL);
 setup_timer_1(T1_DISABLED);
 setup_vref(FALSE);
 output_bit(PIN_A0, 1);
 delay_ms(50000);
 output_bit(PIN_A0, 0);
 delay_ms(50000);
 #include <18F2620.h>
 #device ICD=TRUE
 #device adc=8
 #fuses NOWDT,WDT128,HS, NOPROTECT, NOIESO, NOBROWNOUT, BORV21, NOPUT, NOCPD, STVREN, DEBUG, NOLVP, NOWRT, NOWRTD, NOEBTR, NOCPB, NOEBTRB, NOWRTC, NOWRTB, FCMEN, XINST, NOPBADEN, LPT1OSC, MCLR
 I cannot obtain the good delay, I got 2us high and 2us down. I got a 20MHz x-tall. Maybe I've fogot a fuse or something. Anybody can help me on this?
		| PCM programmer
				|  Posted: Thu Jan 25, 2007 12:04 pm |   |
				|  	  | Quote: |  	  | while(1) {
 delay_ms(50000);
 delay_ms(50000);
 The delays are too long.  Change them both to 500.
  	  | Quote: |  	  | #include <18F2620.h> #device ICD=TRUE
 #device adc=8
 CCS doesn't support the Extended Instruction Set.    Change the fuse
 to NOXINST.
		| Corta
				|  Posted: Thu Jan 25, 2007 1:56 pm |   |
				| wow it's work! Thank you very much!
 | You cannot post new topics in this forum You cannot reply to topics in this forum
