Schneider
Problem with char protocol validation |
Posted: Mon Jan 22, 2007 9:03 pm |
I wrote a function that should return true or false dependind on a string received from the rs232.
boolean isCmd(char *pStr[]){
char sTmp[] = {"#CMD:"};
int iTmp;
iTmp = (strlen(*pStr)-1);
printf("strPar: %s\r\n", *pStr);
printf("strCom: %s\r\n", sTmp);
printf("Match: %u\r\n", strspn(*pStr, sTmp));
printf("Index: %u\r\n", iTmp);
printf("Close: %c\r\n", *pStr[iTmp]);
if ((strspn(*pStr,sTmp)==5) & (*pStr[iTmp] == ';')){
return true;
}else{
return false;
the printf in the function is to trace the values while testing the function.
I use it this way:
char strBuffer[];
// receive data trough rs232 #CMD:123;
gets(strBuffer);
if(isCmd(&strBuffer)){
printf("CMD is valid!\r\n");
}else{
printf("CMD is invalid!\r\n");
everything works fine until the *pStr[iTmp]. it doesn't return the last character in the array. what am i doing whrong?
thanks for any help. |
Posted: Mon Jan 22, 2007 9:28 pm |
I didn't review your code in detail, but this statement here has got a
few problems:
Quote: | if ((strspn(*pStr,sTmp)==5) & (*pStr[iTmp] == ';')){ |
The strspn() function takes two pointers as arguments. You've got
a dereferenced pointer as the first argument. It should be a pointer.
The 2nd thing I see is that your intention is to do a logical operation
on the two expressions but you have a bitwise AND operator.
You should be using the logical AND operator, which is &&.
There might be other problems. Those are just two that I spotted.
This is from the Help file from my old QuickC for Windows:
Syntax: size_t strspn( char *string1, char *string2 );
Returns: The position of the first nonmatching character in string1.
STRSPN.C: This program uses strspn to determine the
length of the segment in the string "cabbage" consisting
of a's, b's, and c's. In other words, it finds the first
non-abc letter.
char string[] = "cabbage";
int result;
result = strspn( string, "abc" );
printf( "The portion of '%s' containing only a, b, or c "
"is %d bytes long\n", string, result );
Schneider
Posted: Tue Jan 23, 2007 6:34 am |
the strspn() is working fine. The only problem in the function is that I'm not obtaining the last char in the parameter string.
when I call the function, i get this feedback on the terminal screen:
assuming that the parameter passed to the function is #CMD:123
strPar: #CMD:123
strCom: #CMD:
Match: 5
Index: 7
Close: ??? (sometimes show some garbadge)
this should return false
and if the parameter passed to the function was #CMD:123;
the function should return true
i don't know why the 'Close' character is not returned when i try to get the *pStr[iTmp] value.
I realy missed the bitwise AND. I will try with the &&, butt the biggest problem is beffore the AND test. |
Mark
Posted: Tue Jan 23, 2007 7:06 am |
Try this:
boolean isCmd(char *pStr)
int iTmp;
iTmp = (strlen(pStr)-1);
printf("strPar: %s\r\n", pStr);
printf("Match: %u\r\n", strspn(pStr, sTmp));
printf("Close: %c\r\n", pStr[iTmp]);
if ((strspn(pStr,sTmp)==5) && (pStr[iTmp] == ';'))
return true;
return false;
char *pStr[] is an array of pointers to strings which is not what you have. You just need a pointer to a string |
Schneider
Posted: Tue Jan 23, 2007 11:41 pm |
you're the best dude.. the problem is solved.. thanks a lot.. |
