Problem with char protocol validation
Schneider
PostPosted: Mon Jan 22, 2007 9:03 pm     Reply with quote
I wrote a function that should return true or false dependind on a string received from the rs232.
boolean isCmd(char *pStr[]){
  char sTmp[] = {"#CMD:"};
  int iTmp;
  iTmp = (strlen(*pStr)-1);
  printf("strPar: %s\r\n", *pStr);
  printf("strCom: %s\r\n", sTmp);
  printf("Match: %u\r\n", strspn(*pStr, sTmp));
  printf("Index: %u\r\n", iTmp);
  printf("Close: %c\r\n", *pStr[iTmp]);
  if ((strspn(*pStr,sTmp)==5) & (*pStr[iTmp] == ';')){
    return true;
  }else{
    return false;
the printf in the function is to trace the values while testing the function.
I use it this way:
   char strBuffer[];
   // receive data trough rs232 #CMD:123;
    gets(strBuffer);
    if(isCmd(&strBuffer)){
      printf("CMD is valid!\r\n");
    }else{
      printf("CMD is invalid!\r\n");
everything works fine until the *pStr[iTmp]. it doesn't return the last character in the array. what am i doing whrong?
thanks for any help.
PostPosted: Mon Jan 22, 2007 9:28 pm     Reply with quote
I didn't review your code in detail, but this statement here has got a
few problems:
The strspn() function takes two pointers as arguments. You've got
a dereferenced pointer as the first argument. It should be a pointer.
The 2nd thing I see is that your intention is to do a logical operation
on the two expressions but you have a bitwise AND operator.
You should be using the logical AND operator, which is &&.
There might be other problems. Those are just two that I spotted.
This is from the Help file from my old QuickC for Windows:
Syntax:  size_t strspn( char *string1, char *string2 );
Returns: The position of the first nonmatching character in string1.
STRSPN.C: This program uses strspn to determine the
length of the segment in the string "cabbage" consisting
of a's, b's, and c's.  In other words, it finds the first
non-abc letter.
   char string[] = "cabbage";
   int  result;
   result = strspn( string, "abc" );
   printf( "The portion of '%s' containing only a, b, or c "
           "is %d bytes long\n", string, result );
Schneider
PostPosted: Tue Jan 23, 2007 6:34 am     Reply with quote
the strspn() is working fine. The only problem in the function is that I'm not obtaining the last char in the parameter string.
when I call the function, i get this feedback on the terminal screen:
assuming that the parameter passed to the function is #CMD:123
strPar: #CMD:123
strCom: #CMD:
Match: 5
Index: 7
Close: ??? (sometimes show some garbadge)
this should return false
and if the parameter passed to the function was #CMD:123;
the function should return true
i don't know why the 'Close' character is not returned when i try to get the *pStr[iTmp] value.
I realy missed the bitwise AND. I will try with the &&, butt the biggest problem is beffore the AND test.
Mark
PostPosted: Tue Jan 23, 2007 7:06 am     Reply with quote
Try this:
boolean isCmd(char *pStr)
  int iTmp;
  iTmp = (strlen(pStr)-1);
  printf("strPar: %s\r\n", pStr);
  printf("Match: %u\r\n", strspn(pStr, sTmp));
  printf("Close: %c\r\n", pStr[iTmp]);
  if ((strspn(pStr,sTmp)==5) && (pStr[iTmp] == ';'))
    return true;
    return false;
char *pStr[] is an array of pointers to strings which is not what you have. You just need a pointer to a string
Schneider
PostPosted: Tue Jan 23, 2007 11:41 pm     Reply with quote
you're the best dude.. the problem is solved.. thanks a lot..
