How can I use the bootloader in PCM example folder ??
arunb
PostPosted: Mon Jan 22, 2007 10:15 am     Reply with quote
Compiler : PCM 3.228
Target: 16F648A, 16F877A
I would like to use the bootloader given in the PICC folder, I have also managed to modify it for a 16F877A mcu, but I find that when I load a program into the mcu, the bootloader gets erased, as a result I have to burn the bootloader using a programmer..
Is this how a bootloader works ?? kindly explain how I can prevent the bootloader from getting erased ...
Unfortuantely I have lost the source code for the above problem, so I may have to work out the program again ....
thanks
arunb
PostPosted: Mon Jan 22, 2007 10:33 am     Reply with quote
The 'keys', are the definitions in bootloader.h. You include this file, with the running program, as well as with the bootloader itself, but in the bootloader program, define the keyword _bootloader, before loading it. In the main program, you load it without this definiton. It then adds these definitions to your 'bootloaded' program:
#define LOADER_END 0x1FF
#define LOADER_SIZE 0x1BF
#build(reset=LOADER_END+1, interrupt=LOADER_END+5)
#org 0, LOADER_END {}
Now, the last two lines of this, move the bootloaded program up, to avoid the bootloader.
