arunb
How can I use the bootloader in PCM example folder ?? |
Posted: Mon Jan 22, 2007 10:15 am |
Compiler : PCM 3.228
Target: 16F648A, 16F877A
I would like to use the bootloader given in the PICC folder, I have also managed to modify it for a 16F877A mcu, but I find that when I load a program into the mcu, the bootloader gets erased, as a result I have to burn the bootloader using a programmer..
Is this how a bootloader works ?? kindly explain how I can prevent the bootloader from getting erased ...
Unfortuantely I have lost the source code for the above problem, so I may have to work out the program again ....
thanks
arunb |
Posted: Mon Jan 22, 2007 10:33 am |
The 'keys', are the definitions in bootloader.h. You include this file, with the running program, as well as with the bootloader itself, but in the bootloader program, define the keyword _bootloader, before loading it. In the main program, you load it without this definiton. It then adds these definitions to your 'bootloaded' program:
#define LOADER_END 0x1FF
#define LOADER_SIZE 0x1BF
#build(reset=LOADER_END+1, interrupt=LOADER_END+5)
#org 0, LOADER_END {}
Now, the last two lines of this, move the bootloaded program up, to avoid the bootloader.
