PIC18F4520 Reset
Luis F
PIC18F4520 Reset
PostPosted: Tue Jan 16, 2007 9:18 pm     Reply with quote
I migrate from PIC18F452 to PIC18F4520 ,but when I do a hardware reset (push button in MCLR) the program stop to run,
i need to turn off the power supply and turn on again and the program run normaly.
Any ideas? Question
This is a single test code
#include <18F4520.h>
#device adc=8
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES HS                       //High speed Osc (> 4mhz)
#FUSES NOPROTECT                //Code not protected from reading
#FUSES BORV42                   //Brownout reset at 4.2V
#FUSES PUT                      //Power Up Timer
#FUSES NOCPD                    //No EE protection
#FUSES NODEBUG                  //No Debug mode for ICD
#FUSES LVP                      //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES NOWRT                    //Program memory not write protected
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#FUSES PBADEN                   //PORTB pins are configured as analog input channels on RESET
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES NOCPB                    //No Boot Block code protection
#FUSES LPT1OSC                  //Timer1 configured for low-power operation
#FUSES MCLR                     //Master Clear pin enabled
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#use delay(clock=10000000)
#define Led    pin_A5
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_vref(VREF_LOW|-2);
   setup_low_volt_detect(FALSE);
   setup_oscillator(False);
   while(True)
    {output_low(Led);
     delay_ms(200);
     output_high(Led);
     delay_ms(200);
[/code]
PostPosted: Wed Jan 17, 2007 12:09 am     Reply with quote
I need to turn off the power supply and turn on again and the program
run normally.
Make sure you have a pull-up resistor on the MCLR pin.
Use 10K for Microchip ICD2, or 47K for CCS ICDU-40.
#FUSES LVP
Change this fuse to NOLVP.
The value of -2 is not defined for this function. It's there because
of a bug in the PCWH Wizard. Just delete that line. You don't
need it. The Vref module comes up in a disabled state upon
power-up reset.
