I migrate from PIC18F452 to PIC18F4520 ,but when I do a hardware reset (push button in MCLR) the program stop to run,
i need to turn off the power supply and turn on again and the program run normaly.
Any ideas?
This is a single test code
#include <18F4520.h>
#device adc=8
#FUSES HS //High speed Osc (> 4mhz)
#FUSES BORV42 //Brownout reset at 4.2V
#FUSES PUT //Power Up Timer
#FUSES LVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
I need to turn off the power supply and turn on again and the program
run normally.
Make sure you have a pull-up resistor on the MCLR pin.
Use 10K for Microchip ICD2, or 47K for CCS ICDU-40.
#FUSES LVP
Change this fuse to NOLVP.
setup_vref(VREF_LOW|-2);
The value of -2 is not defined for this function. It's there because
of a bug in the PCWH Wizard. Just delete that line. You don't
need it. The Vref module comes up in a disabled state upon
power-up reset.
