Two dimensional arrays for strings
csanders
PostPosted: Mon Dec 11, 2006 9:59 pm     Reply with quote
I am trying to create an error log in memory using a 2 dimensional array to store a verbose message, but cannot get the code to compile.
char errorlog[10][20];
int8 index;
//on error, place error message in array
if (index < 18)
   errorlog[index++][0] = "error msg";   //compilation error occurs here
Does anyone know what I am doing wrong?
treitmey
PostPosted: Mon Dec 11, 2006 10:20 pm     Reply with quote
This is what I do. Perhaps it is that I use const char??
replace STDERR with any stream you've defined.
const char error_txt[16][16] =
  "USART overflow",  // -0-
  "TXBuffer ovrflw", // -1-
  "RXBuffer ovrflw", // -2-
  "Bad Checksum",    // -3-
  "LCD busy",        // -4-
  "5",  // -5-
  "6",  // -6-
  "7",
  "8",
  "9",
  "10",
  "11",
  "12",
  "13",
  "14",
  "NO ERRORS"
//somewhere else in code
bit_set(ERRORS,1);//set error flag bit 1 for tx overflow
unsigned int16 ERRORS;
void ChkErr(void) //print out any errors that occured
  int8 chk=0;
  if (ERRORS==0){return;} //if no errors jump right back out
  for(chk=0;chk<16;chk++)
    if (bit_test(ERRORS,chk))
      bit_clear(ERRORS,chk);
      fprintf(STDERR,"ERROR(%U): %s.\r\n",chk,error_txt[chk]);
      tx_buffer(NACK,sizeof(NACK));
      rx_indx_i=rx_indx_o=0;
PostPosted: Tue Dec 12, 2006 3:16 am     Reply with quote
To load data from a 'constant' string, into the array, you need to use 'memcpy' or 'strcpy'. So:
   strcpy(&errorlog[index++][0],"error msg");
You can't just 'hand' a string into the array.
As a separate comment, what is going to happen when index is greater than 9?. You are trapping it at 18, but the array dimension on this axis, only goes 0..9.
