csanders
| Two dimensional arrays for strings |
Posted: Mon Dec 11, 2006 9:59 pm |
I am trying to create an error log in memory using a 2 dimensional array to store a verbose message, but cannot get the code to compile.
char errorlog[10][20];
int8 index;
//on error, place error message in array
if (index < 18)
errorlog[index++][0] = "error msg"; //compilation error occurs here
Does anyone know what I am doing wrong?
Thanks |
treitmey
Posted: Mon Dec 11, 2006 10:20 pm |
This is what I do. Perhaps it is that I use const char??
replace STDERR with any stream you've defined.
| Code: | const char error_txt[16][16] =
"USART overflow", // -0-
"TXBuffer ovrflw", // -1-
"RXBuffer ovrflw", // -2-
"Bad Checksum", // -3-
"LCD busy", // -4-
"5", // -5-
"6", // -6-
"7",
"8",
"9",
"10",
"11",
"12",
"13",
"14",
"NO ERRORS"
//somewhere else in code
bit_set(ERRORS,1);//set error flag bit 1 for tx overflow
unsigned int16 ERRORS;
void ChkErr(void) //print out any errors that occured
int8 chk=0;
if (ERRORS==0){return;} //if no errors jump right back out
for(chk=0;chk<16;chk++)
if (bit_test(ERRORS,chk))
bit_clear(ERRORS,chk);
fprintf(STDERR,"ERROR(%U): %s.\r\n",chk,error_txt[chk]);
tx_buffer(NACK,sizeof(NACK));
rx_indx_i=rx_indx_o=0;
Posted: Tue Dec 12, 2006 3:16 am |
To load data from a 'constant' string, into the array, you need to use 'memcpy' or 'strcpy'. So:
strcpy(&errorlog[index++][0],"error msg");
You can't just 'hand' a string into the array.
As a separate comment, what is going to happen when index is greater than 9?. You are trapping it at 18, but the array dimension on this axis, only goes 0..9.
