programming without erasing bootloader area
moutinho
View user's profile Send private message Visit poster's website MSN Messenger
PostPosted: Tue Nov 28, 2006 8:26 pm     Reply with quote
How can I program an application using ICD2 without erasing an existing bootloader area located in the high memory?
Thanks,
Andre
PostPosted: Wed Nov 29, 2006 1:04 pm     Reply with quote
This is really a question for the Microchip ICD2 forum.
http://forum.microchip.com/tt.aspx?forumid=49
But, to give you an answer, go to the Programmer / Settings menu
in MPLAB. The "MPLAB ICD2 Settings" window will pop up. Select
the "Program" tab. On that window, you can set the memory range
that will be programmed. To display the MPLAB help for that window,
press the F1 key when you're viewing the window. For more help,
ask a question on the MPLAB ICD2 forum at the link above.
