But, to give you an answer, go to the Programmer / Settings menu
in MPLAB. The "MPLAB ICD2 Settings" window will pop up. Select
the "Program" tab. On that window, you can set the memory range
that will be programmed. To display the MPLAB help for that window,
press the F1 key when you're viewing the window. For more help,
ask a question on the MPLAB ICD2 forum at the link above.
