Delaying sensor signal for PC io card
leesing2k3
PostPosted: Fri Nov 17, 2006 9:08 am     Reply with quote
I have an application that needs to detect a sensor signal.
The bad part is, the signal is too fast for the pc to detect.
Currently I am using a PIC to collect the signal from the sensor then delay the pulse so that the pulse is slow enuf for the pc to capture by using io card.
I am just wondering if there is any other way of doing this besides using PIC?
Thanks in advance.
SET
PostPosted: Fri Nov 17, 2006 10:13 am     Reply with quote
Use a monostable to stretch the pulse
HTH
leesing2k3
PostPosted: Tue Nov 28, 2006 4:47 am     Reply with quote
oh, thank you very much
SherpaDoug
PostPosted: Tue Nov 28, 2006 5:09 pm     Reply with quote
A more complicated but more elegant way is to have the sensor set a flip flop, which the PIC will reset once it has been read.
