I have an application that needs to detect a sensor signal.
The bad part is, the signal is too fast for the pc to detect.
Currently I am using a PIC to collect the signal from the sensor then delay the pulse so that the pulse is slow enuf for the pc to capture by using io card.
I am just wondering if there is any other way of doing this besides using PIC?
Thanks in advance.
SET
Posted: Fri Nov 17, 2006 10:13 am
Use a monostable to stretch the pulse
HTH
leesing2k3
Posted: Tue Nov 28, 2006 4:47 am
oh, thank you very much
SherpaDoug
Posted: Tue Nov 28, 2006 5:09 pm
A more complicated but more elegant way is to have the sensor set a flip flop, which the PIC will reset once it has been read. _________________ The search for better is endless. Instead simply find very good and get the job done.
