problem defining a struct
shew82
PostPosted: Tue Oct 24, 2006 8:12 am     Reply with quote
I am attempting to define a stuct to make dealing with a data message easier...
I initially defined the struct as:
struct retrieved_messageB {
   unsigned messageID:    5;
   unsigned int dataA;
   unsigned dataB:         4;
   unsigned dataC:         4;
   unsigned int dataD;
   unsigned int dataE;
   unsigned dataF:         4;
   unsigned dataG:       4;
   unsigned dataH:       6;
   unsigned dataI:         2;
   unsigned dataJ:         1;
   unsigned dataK:         1;
   unsigned spare:         2;
which compiled fine... however, I realised that I had put my stucture in the wrong order. I then carried out the, what I thought was, relatively simple task of re-ording the struct to produce:
   unsigned spare:         2;
   unsigned dataK:         1;
   unsigned dataJ:         1;
   unsigned dataI:         2;
   unsigned dataH:          6;
   unsigned dataG:         4;
   unsigned dataF:         4;
   unsigned int dataE;
   unsigned int dataD;
   unsigned dataC:         4;
   unsigned dataB:         4;
   unsigned int dataA;
which does NOT compile! giving the error "Error 35... Line 132(17,18): Number of bits is out of range" where line 132 is the line with "unsigned dataH".
Any ideas!?
Thanks,
Shaun
treitmey
PostPosted: Tue Oct 24, 2006 8:31 am     Reply with quote
I think it is complaining because they need to line up on byte borders
 unsigned spare:         2;
   unsigned dataK:         1;
   unsigned dataJ:         1;
   unsigned dataI:         2;
   unsigned dataH:          6;
   unsigned dataG:         4;
Can you pad/waist some bits to get them on byte boundaries
 unsigned spare:         2;
   unsigned dataK:         1;
   unsigned dataJ:         1;
  unsigned waisted:         4; //8
   unsigned dataI:         2;
   unsigned dataH:          6;//8
   unsigned dataG:         4;//last 4 can trail off i think
or you will have to read them in, then make a shift and mask to put them is the data area you want. Perhaps a union will work here?? will a union work with bit places??
