which compiled fine... however, I realised that I had put my stucture in the wrong order. I then carried out the, what I thought was, relatively simple task of re-ording the struct to produce:
which does NOT compile! giving the error "Error 35... Line 132(17,18): Number of bits is out of range" where line 132 is the line with "unsigned dataH".
Any ideas!?
Thanks,
Shaun
treitmey
Posted: Tue Oct 24, 2006 8:31 am
I think it is complaining because they need to line up on byte borders
unsigned dataI: 2;
unsigned dataH: 6;//8
unsigned dataG: 4;//last 4 can trail off i think
or you will have to read them in, then make a shift and mask to put them is the data area you want. Perhaps a union will work here?? will a union work with bit places??
