		| Author | Message |
		| nurquhar
				| Why does #use rs232 ENABLE=PIN not work with puts or printf |
				|  Posted: Sun Oct 08, 2006 1:08 am |   |
				| I have an odd problem with the way puts and printf are working when using the #use rs232 ENABLE feature.  Basically I can see the output on Hyperterminal from the putc() but a string sent with puts() or printf() sends blanks.  I am using SP485REN chip with B0 connected to the DE and /RE inputs.
 The following prog compiled with 3.249 gives the following output.
  	  | Code: |  	  | // CPU Clock Freq
 #define   FOSC   20000000
 #define BAUDRT   9600
 #include <16F876A.h>
 #include <stdio.h>
 #fuses HS,NOWDT,PUT,NOPROTECT,NOBROWNOUT,NOLVP,NOCPD,NOWRT
 #use delay(clock=FOSC)
 #use rs232 (baud=BAUDRT, xmit=PIN_C6, rcv=PIN_C7, PARITY=N, BITS=8, ENABLE=PIN_B0)
 unsigned int ch ;
 putc('O') ;
 putc('k') ;
 putc('\r') ;
 putc('\n') ;
 puts("Hello from Puts") ;
 putc('H') ;
 putc('e') ;
 putc('l') ;
 putc('l') ;
 putc('o') ;
 putc('\r') ;
 putc('\n') ;
 while(1) {
 if (kbhit()) {
 ch = getc() ;
 putc(ch) ;
 if (ch == 0x31) {
 puts("Puts a long string to test the output") ;
 putc('N') ;
 putc('o') ;
 putc(' ') ;
 putc('1') ;
 putc('\r') ;
 putc('\n') ;
 The output on the terminal with me typing 1,2,3
  	  | Quote: |  	  | Ok ts
 Hello
 1ut
 No 1
 23
 I thought puts()/printf used putc at the bottom level ?  However it seems to be doing the enable in a different way.
 Any ideas ?
		| nurquhar
				|  Posted: Sun Oct 08, 2006 1:29 am |   |
				| I made a small mod and used my own puts which works ! Whats wrong with CCS version ?
  	  | Code: |  	  | // CPU Clock Freq #define   FOSC   20000000
 #define BAUDRT   9600
 #include <stdio.h>
 char buf[40] ;
 void myputs(char *str)
 for(; *str != 0 ; str++) {
 putc(*str) ;
 putc('\r') ;
 putc('\n') ;
 unsigned int ch ;
 putc('O') ;
 putc('k') ;
 putc('\r') ;
 putc('\n') ;
 //   puts("Hello from Puts") ;
 strcpy(buf, "Hello from Puts") ;
 myputs(buf) ;
 putc('H') ;
 putc('e') ;
 putc('l') ;
 putc('l') ;
 putc('o') ;
 putc('\r') ;
 putc('\n') ;
 while(1) {
 if (kbhit()) {
 ch = getc() ;
 putc(ch) ;
 if (ch == 0x31) {
 //            puts("Puts a long string to test the output") ;
 strcpy(buf, "Puts a long string to test the output") ;
 myputs(buf) ;
 putc('N') ;
 putc('o') ;
 putc(' ') ;
 putc('1') ;
 putc('\r') ;
 putc('\n') ;
 Output for 1,2,3
  	  | Quote: |  	  | Ok Hello from Puts
 Hello
 1Puts a long string to test the output
 No 1
 23
 [/code]
		| PCM programmer
				|  Posted: Sun Oct 08, 2006 2:16 pm |   |
				| puts() is a macro that calls printf.   Here's the macro definition from stdlib.h.
  	  | Code: |  	  | #define puts(s) {printf(s); putchar(13); putchar(10);} |
 Here's the stdlib.h file location:    c:\program files\picc\drivers\stdio.h
 So the problem is in printf.
 Here's a report in April 2005 of the same problem.
 http://www.ccsinfo.com/forum/viewtopic.php?t=22421
 It appears that 'enable' only works with putc().   So one way to do
 a work-around would be to use the re-direction feature of the CCS
 printf() function, and send the output to putc.    Example:
  	  | Code: |  	  | #include <16F877.h>
 #fuses XT, NOWDT, NOPROTECT, PUT, BROWNOUT, NOLVP
 #use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, Enable=PIN_B0, ERRORS)
 my_putc(char c)
 putc(c);
 printf(my_putc, "Hello World");
 I looked at the .LST file, and this does work.
		| nurquhar
				|  Posted: Mon Oct 09, 2006 12:52 am |   |
				| Dear PCM
 Thanks for confirming what I suspected.  ie its a long standing CCS bug.  Re-directing through "myputc" with printf(myputc, "xxx") is certanily a good work around, however it would be much better if CCS fixed it.  I am guesing the fix will consume another valuable stack level.  Especialy if you only have an level 8 stack to start with !
 I'll post it as bug to CCS, you never know if may get fixed by April 2007.
 | You cannot post new topics in this forum You cannot reply to topics in this forum
