Why does #use rs232 ENABLE=PIN not work with puts or printf
nurquhar
PostPosted: Sun Oct 08, 2006 1:08 am     Reply with quote
I have an odd problem with the way puts and printf are working when using the #use rs232 ENABLE feature. Basically I can see the output on Hyperterminal from the putc() but a string sent with puts() or printf() sends blanks. I am using SP485REN chip with B0 connected to the DE and /RE inputs.
The following prog compiled with 3.249 gives the following output.
// CPU Clock Freq
#define   FOSC   20000000
#define BAUDRT   9600
#include <16F876A.h>
#include <stdio.h>
#fuses HS,NOWDT,PUT,NOPROTECT,NOBROWNOUT,NOLVP,NOCPD,NOWRT
#use delay(clock=FOSC)
#use rs232 (baud=BAUDRT, xmit=PIN_C6, rcv=PIN_C7, PARITY=N, BITS=8, ENABLE=PIN_B0)
   unsigned int ch ;
   putc('O') ;
   putc('k') ;
   putc('\r') ;
   putc('\n') ;
   puts("Hello from Puts") ;
   putc('H') ;
   putc('e') ;
   putc('l') ;
   putc('l') ;
   putc('o') ;
   putc('\r') ;
   putc('\n') ;
   while(1) {
      if (kbhit()) {
         ch = getc() ;
         putc(ch) ;
         if (ch == 0x31) {
            puts("Puts a long string to test the output") ;
            putc('N') ;
            putc('o') ;
            putc(' ') ;
            putc('1') ;
            putc('\r') ;
            putc('\n') ;
The output on the terminal with me typing 1,2,3
Ok
ts
Hello
1ut
No 1
23
I thought puts()/printf used putc at the bottom level ? However it seems to be doing the enable in a different way.
Any ideas ?
nurquhar
PostPosted: Sun Oct 08, 2006 1:29 am     Reply with quote
I made a small mod and used my own puts which works ! Whats wrong with CCS version ?
// CPU Clock Freq
#define BAUDRT   9600
#include <stdio.h>
char buf[40] ;
void myputs(char *str)
   for(; *str != 0 ; str++) {
      putc(*str) ;
   putc('\r') ;
   putc('\n') ;
   unsigned int ch ;
   putc('O') ;
   putc('k') ;
   putc('\r') ;
   putc('\n') ;
//   puts("Hello from Puts") ;
   strcpy(buf, "Hello from Puts") ;
   myputs(buf) ;
   putc('H') ;
   putc('e') ;
   putc('l') ;
   putc('l') ;
   putc('o') ;
   putc('\r') ;
   putc('\n') ;
   while(1) {
      if (kbhit()) {
         ch = getc() ;
         putc(ch) ;
         if (ch == 0x31) {
//            puts("Puts a long string to test the output") ;
            strcpy(buf, "Puts a long string to test the output") ;
            myputs(buf) ;
            putc('N') ;
            putc('o') ;
            putc(' ') ;
            putc('1') ;
            putc('\r') ;
            putc('\n') ;
Output for 1,2,3
Ok
Hello from Puts
Hello
1Puts a long string to test the output
No 1
23
[/code]
PostPosted: Sun Oct 08, 2006 2:16 pm     Reply with quote
puts() is a macro that calls printf. Here's the macro definition
from stdlib.h.
#define puts(s) {printf(s); putchar(13); putchar(10);}
Here's the stdlib.h file location: c:\program files\picc\drivers\stdio.h
So the problem is in printf.
Here's a report in April 2005 of the same problem.
http://www.ccsinfo.com/forum/viewtopic.php?t=22421
It appears that 'enable' only works with putc(). So one way to do
a work-around would be to use the re-direction feature of the CCS
printf() function, and send the output to putc. Example:
#include <16F877.h>
#fuses XT, NOWDT, NOPROTECT, PUT, BROWNOUT, NOLVP
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, Enable=PIN_B0, ERRORS)
my_putc(char c)
putc(c);
printf(my_putc, "Hello World");
I looked at the .LST file, and this does work.
nurquhar
PostPosted: Mon Oct 09, 2006 12:52 am     Reply with quote
Dear PCM
Thanks for confirming what I suspected. ie its a long standing CCS bug. Re-directing through "myputc" with printf(myputc, "xxx") is certanily a good work around, however it would be much better if CCS fixed it. I am guesing the fix will consume another valuable stack level. Especialy if you only have an level 8 stack to start with !
I'll post it as bug to CCS, you never know if may get fixed by April 2007.
