knobby67 Guest
| Using input() with a variable |
Posted: Thu Sep 28, 2006 9:41 am |
Hello Im hoping someone can help me out with this, basically I have a structure define as below
struct meter_input
byte input;
long count;
char status;
I then have structure like the below
STRUCT meter_input _10pCoinInput=
PIN_B0,
0,
LO,
Where input is used to store the pin to be read with the library function input()
I call the function
ReadStatus(&_10pCoinInput);
The ReadStatus is as follows
void ReadStatus(struct meter_input *meter)
if(meter->status==HIGH) //is the status high
if(!input(meter->input)) //has the input dropped low
meter->status=LO;
meter->count++;
return;
However this gives a error
Expression must evaluate to a constant
As far as Im awear it does? Input is PIN_B0, Ive tried defining input with a const ie const byte input; but this gives an error can anyone advise?
Thanks |
